Hallo Studio One Benutzer,
ein neues Feature-Update von Studio One ist ab sofort erhältlich. Die Version 5.1 enthält etliche Neuerungen und Userwünsche und hält für alle Anwender etwas bereit. Viel Freude beim Erforschen und allen einen schönen, gemütlichen Herbst! Das Update ist wie immer kostenlos und hier gehts zum offiziellen Ankündigungsthread.
viewtopic.php?f=151&t=42113
Ari
Release Notes
New features and improvements:
Recording and Mixing
  • Retrospective Recording
  • Track/Channel search and filter options
  • Bypass option for Gain Envelopes
  • Drag & drop send chains
Arrangement and Editing
  • Improved presentation of Global Tracks
  • Secondary Timeline Ruler option
  • New combined Signature Track (time and key signature changes)
  • Transfer key signature events using ARA
  • Global Tracks in Editors (Marker, Arranger, Chords, Signature)
  • Score Printing
  • Score View: Key Signature Changes
  • Score View: Staff Presets
  • Score View: Staff Settings
  • Score View: Alternative views
  • Score View: Noteheads selection
  • [Impact XT] Colorized events in Pattern Editor
Live Performance
  • Edit indicator for Patches
  • External instrument support for Patches
Plug-ins and Instruments
  • [Ampire and Pedalboard] New Compressor and Gate FX pedals
  • Drag & Drop FX pedals between Ampire and Pedalboard
Workflow
  • [Start Page] Search function for songs, projects, and shows
  • [Project Page] Digital Release never adds a 2-second pause
Improved ATOM integration
  • 4 Banks of assignable Encoders
  • 4 Banks of assignable Pad Commands
  • Scales in keyboard mode
  • Open Note FX editor option
  • Replace instrument option
General
  • Alternative views for Instrument Rack
  • [macOS] Switchable hardware graphics acceleration
  • [Windows] High-DPI scaling option re-enabled
  • [Windows] Improved user experience with consumer-grade non-ASIO audio devices
The following issues have been fixed:
  • [Windows] flickering play cursor at 175% scaling
  • [Windows] Irregular grid lines at 125%, 150% and 175% scaling
  • [macOS] Note event vs. audio timing off grid at high buffer settings
  • [macOS HiSierra] When pinning Soothe 2, all other plug-in windows are stalled
  • [macOS] Graphical performance degrades when scrolling collapsed folder
  • [macOS] No redrawing of icons when switching resolution
  • [macOS] Text not clipped in browser tile
  • [macOS] Unwanted wrapping in certain text boxes
  • [macOS] Laggy graphics with certain 3rd party plug-ins
  • [Browser] Can't delete certain custom folders
  • [Browser] Crash on expanding certain track folders
  • [Browser] Selecting multiple items in Tree View doesn't work on first click w/ Shift
  • [Mixer] Monitoring live input from bus no longer possible
  • [Mixer] Multi Instrument primary/master channel name is not retained
  • [Mixer] Pipeline XT not passing audio when inserted to Listen Bus
  • [Mixer] Solo safe in aux channels forces realtime render when bouncing a virtual instrument track
  • [Mixer] Keyboard shortcut "add gain trim" always opens 1st insert slot
  • [Presence XT Editor] Decimal shift when entering tune values
  • [Presence XT Editor] Wrong conversion when entering negative 'Tune' values
  • [AutoFilter] Leftover TODO tooltip
  • [Impact XT] Sample offset settings are not recalled
  • [Exchange] .ioconfig "installs" to default "Download" folder
  • [Note FX] Arpeggiator chokes up in certain situations
  • Audio miscalculation on extreme tempo edits
  • Audition is suspended too early on recording with Auto Punch
  • Automation may migrate to a different track
  • Can't create audio track above a folder track via drag and drop
  • Can't duplicate a transformed Instrument Track
  • Certain original audio cannot be dragged into arrangement
  • Delay compensation / latency not updated unless the plugin is reset manually
  • Duplicating automation sometimes not working properly
  • Event text position is odd on high vertical zoom levels
  • Export mixdown is longer than loop range when an AUX channel is present
  • Graphic ghost and font space issue when event badges are disabled
  • In Step Recording mode, cursor does not advance after input notes when the Tempo Track contains nodes
  • Last track in the Arrangement cannot be resized if it has been minimized
  • Listen bus metering options are following audio track metering options
  • Misc 3rd party plug-in window resize issues (Kilohearts, Melda Productions, Waves...)
  • Noise when loading a song w/ Ampire when Dropout Protection is set to Maximum
  • Open folder range selection disappears on copy/paste command
  • Potential crash when editing audio bend markers
  • Second external device plugged-in is not auto-detected sometimes
  • Context menu reacts differently to mouse clicks on macOS and Windows
  • "Stop at Marker" is being ignored in certain situations
  • Unwanted behavior when copying sections w/ enclosed automation
  • Updating an Instrument+FX Preset creates .preset file instead of .instrument
by baseliner on Fri Nov 06, 2020 5:01 pm
ist es in S1 5 machbar, dass der Fokus automatisch von "Instrument" auf "Fokus:Global" springt, wenn ich von einer Spur mit plugin auf eine Audiospur wechsle.
