Hallo Studio One-User,
es ist Frühling und wir haben ordentlich Frühjahrsputz gemacht! Dieses Wartungsupdate enthält eine ganze Menge Verbesserungen und Fixes. Weit über 70 kleine nette Details wurden mit Usern weltweit besprochen und überarbeitet. Wir wünschen Euch jetzt erst recht viel Spaß beim Musikmachen mit Studio One und eine schöne und inspirierende Frühlingszeit! Ari _______________________________________________________________________ This document lists all Studio One 3 maintenance updates and their included fixes and improvements. Version 3.2.1 Release Notes (March 30, 2016): New features and improvements: • Save and restore Studio 192, RM and AI mixer settings (Fat Channel, Pre-amp) • New button in mixer settings controls restores audio device settings • Pass-through mode for Mix Engine FX • New option allows Mix Engine FX plug-ins in a downstream bus (like Main Out) to process all upstream channels, even if a bus is inserted in between) • Different indicator LED colors for different Mix Engine FX routings • Added 23.98 (23.976) frame-rate support for HD video • Show relative value tooltip when using transform tool • VCA Channel - Show/Hide Targets • Loop follows selection shouldn't activate Loop • Zoom Tool available in Music Editor • VCA Fader should follow multiple selected tracks • Option to play overlaps in create song dialog • Option to switch off auto color • Return to Start on Stop without view jump (when editing) • Group tracks hidden in hidden folder • Suspend “Loop follows selection” when loop has been changed manually • Save play start marker in song • [Win] Updated GEAR CD burning drivers The following issues have been fixed: • [OSX] Sample Rate Mismatch In OS X 10.8.5 and 10.9.5 • [OSX] Preview in file selector missing • [OSX] Help Viewer not brought to front again • Putting a Main bus automation under a Track folder hides the main bus • Shift modifier conflict • XLN audio plugin stalls progress dialog • Crossfade not working after applying it • Crash when loading song • Midi notes are not recorded correctly using Repeater in input mode • Repeater's Gate causes unpredictable playback at low settings • Groove Programs B to G not properly recalled • VCA Fader only shows metering while Peak/RMS is selected • Auto-scroll not applied again after activating it • X Fade: hard to get back to linear • Changing Note velocity repeatedly by mouse input won't go below 13/10% • Arranger area (partially) black after closing extended editor • Return to Last Locate on Stop • Input Level meter pre inserts (was post in 3.1.1) • Multi-output instruments track assignment issue • Invert Macro Control doesn't work properly • FX Wet/Dry broken when saving the song for the first time • FX Sends can be dragged on insert FX • [Mai Tai] Pitch & Key follow doesn't work correctly • Markers are unnecessarily duplicated when created from Arranger sections • Automation volume drop when adding VCA • Micro-view state not recalled when instantiating from thumbnail or plugin name • Vertical zoom state not restored by Restore Zoom State • Group Comping: switching layers for grouped tracks • Unexpected result on numerical changes to event start inside part • Start of audio event within part snaps to wrong position after specific action • Slip-editing single short Event within part not correctly redrawn in editor • Go to next/prev track is not working on Project Page • "Solo follows selection" broken for Folder Tracks attached to a VCA • Mute and Solo key commands don’t work for VCA's • Doubled audition notes sent when using arrow keys to switch • Pro EQ "Waterfall" moving faster while editing a curve • Listen tool as alternative tool does not solo channel • Crash after drawing on tempo track after Scale Time, with Scratchpad open • External Instrument Bounce broken for multi-channel MIDI • Channel editor opens in detached Melodyne editor • Marker color does not update when changed with mouse wheel (suppressed now) • When "Show Automation" is enabled, automation data is always pasted to displayed lane • Start region of successively recorded audio event is not exact (but early) • Return to Start on Stop is ignored on Record • Click in Empty Space does not locate in playback • Last CC node in part always being set to the last CC value before punch out • MIDI CC data resets to last value after loop cycle • Record Mix MIDI CC data in a loop, randomly replaced for blanks • Bus ends up in folder Bus when dragging folder past other Bus in console • DDP cd-protocol.html is missing EAN code
danke für das Update, ich glaube, ich bin gerade über einen Bug in v3.2.1 gestolpert. Probiert doch bitte mal aus, ob ihr das reproduzieren könnt: - In einem Song in die Audio I/O Einstellungen gehen - Auf den Namen eines Eingangskanal Doppelklicken, damit dieser umbenannt werden kann - Beim Versuch, das Namensfest mit der "Tab-Taste" zu verlassen, stürzt S1 bei mir reproduzierbar ab. Gruß Matze |
Damageplan wroteProbiert doch bitte mal aus, ob ihr das reproduzieren könnt: Nicht unbedingt Platz 1 meiner Bugs-to-be-fixed, aber ja, kann ich hier nachvollziehen mit OSX 10.10...
Lukas Ruschitzka
Studio One Specialist Advanced Studio One Tutorials || Free Studio One Scripts || Studio One Tutorial Database || Studio One Toolbox [ s1toolbox.com ] Core i7 3.24 GHz, Windows 10, 24 GB RAM, RME HDSP 9632, PreSonus FaderPort, PreSonus Monitorstation, PreSonus Eris 5 Clavia Nord Stage 3 - Moog Sub 37 - YAMAHA MoXF6 - M-Audio Axiom Pro 61 - Kawai ES-920 - Studio One 5 - Notion 6 - Orchestral Tools Junkie XL Horns, ProjectSAM Symphobia, Cinematic Studio Series, Strezov Sampling Afflatus, VSL Synchron Special Edition, KOMPLETE 9 Ultimate |
Ja dieser Mac-only Bug ist bereits bekannt, hat es aber leider nicht mehr in diesen Release geschafft. Ist aber bereits in Arbeit und wird beim Folge-release berücksichtigt. Der Frühling hat ja auch grad erst angefangen.
Gruß Ari
Wenn du einen Mix Engine FX auf'm Master hast und mehrere Spuren, die in einen Bus gehen, dann wirkt der Mix FX nur auf den gesamten Bus, aber nicht einzeln auf die Spuren im Bus. Du kannst also mit dem Console Shaper Crossover zwischen dem Bus und anderen Spuren/Bussen hinkriegen, aber nicht zwischen den einzelnen Spuren im Bus.
Mit pass-through mode wird der Mix FX zu den einzelnen Spuren "durchgereicht".
Lukas Ruschitzka
Hallo,
wenn du einen Fehler gefunden hast oder eine Frage, dann mach doch einen eigenen Thread dazu auf. Dieses Thema hier ist ja im Prinzip hinfällig, da es längst eine nächste Version gibt. Gruß Ari
