I have a new Wind Controller. Its a very new product, the Lekholm DM-48 midi harmonica. It has no onboard sounds. I've been able to set it up using the REASON Demo and Acoustic Electro Waves synth patches, so I know it works.
But when I try to use it with Presonus, I can add it as an instrument, I can see it working in the Midi Monitor, but I can't get it to actually play any of the instruments like Mai Tai or anything else. The Mai Tai plug in makes sound when I mouse click on its keyboard, so that's working. And I can see the DM-48 listed and responding under "Expression" and in the Midi Monitor. But how do I get it to play the Mai Tai?
Step by step as if I were a five year old instructions would be appreciated. Thanks.
by cristofe on Wed May 03, 2017 12:48 pm
I'm not familiar with that particular instrument but properly setting it up in Studio One should be no different than any other external MIDI controller......their are many video tutorials out there:
https://www.google.com/search?q=setting+up+external+midi+controllers+in+studio+one&oq=setting+up+external+midi+controllers+in+studio+one&aqs=chrome..69i57j0.15884j0j7&sourceid=chrome&ie=UTF-8#q=setting+up+external+midi+controllers+in+studio+one&tbm=vid
The problem may perhaps lie in properly setting up send/receive channels in your controller and the instrument you're trying to play. I've used some guitar style MIDI controllers that were a bit squirrly in that respect.
